How does this site work
wiab4355
Hello there, just joined and typed "maps" into the search box and got... well, I don't know what I got - nothing to do with the Google Maps app, as far as I can see!
Anyway if anyone can help with my problem... there's a facility to download and save portions of maps that you can use offline, but my tablet doesn't seem to be able to do do that!
Tablet is noname chinatab MID, with ICS, don't know what more info is needed, just ask
Ian
Hi Ian, and welcome to AF :)
Probably the best place to discuss this would be the Android Applications forum, in the Android Discussion section.
For my guess at the answer, what version of Maps do you have? In the Maps app go to settings -> about and it will tell you. The most recent versions (I have 6.10, but it was available a version or two before that) let you store easily using "menu -> make available offline" when looking at a map, so if that option isn't there you probably have an older version. You should be able to update via the Play Store.
Good luck
Thanks, I'll check on that. May I carry on this conversation here or should I start again in the Android Applications forum?
Ian
Ian
Welcome to Android Forums Ian! I would start another conversation in the Android App's section so you could get better responses as this area is just for introductions. :)
