How does Timeriffic work?
Dabrador
Have a question about Timeriffic and can't find the answer...
I was using Silent Time until the latest update caused some problems. With that app, you indicate a range of time to silence the phone. For example, I could silence the phone from 10pm to 6am...a range of time.
With Timeriffic, I don't see how you schedule a range of time, just a start time. How do I schedule a period of time for the phone to be silent?
Thanks.
Thanks.
You actually schedule an end time.
Make a schedule for the time you want it to change again and choose your settings. Just like you set it up for a "Start time."
It changes your settings at given times, not change at 10pm for 6 hours if that is what you are thinking. You tell it each time it is supposed to change and how it is supposed to change.
