1st my Eeglish not Good its very BAD
SORRYYYYY
you can use android mobile and tablet
Steps
Download this PdaNet android ( http_://junefabrics.com/android/download.ph_p ) Delete " _ "
Graphic1
Graphic2
Graphic3
run your setup file and connet usb android mobile,All Finish
Plz Check this Files
Graphic6
Start -> Control panel -> Network Connections -> Pda Net Broadband Connection
ok, now your android have this apps
PdaNet (android apps) its not have your mobile install this (APK) files in your installing PdaNet folde.
Graphic7
PdaNetBase.apk - > install android mobile or tablet
PdaNet.apk - > android mobile only
PdaNetTablet.apk - > android Tablet only
Graphic8
now run you android mobile PdaNet app
and Run PadNet on your pc
Now you can Connect PC and Android Mobile.
Good Luck
This is my 1st Post i cant Attach images.Sorry
MY ENGLISH NOT GOOD SORRY
any Problem Contact ME (vidura1991@gmail.com)
