how is lenovo k8 note?
K8 Note full specs:
https://www.gsmarena.com/lenovo_k8_note-8794.php
Dimensions 154.5 x 75.9 x 8.5 mm (6.08 x 2.99 x 0.33 in)
Weight 180 g (6.35 oz)
SIM Dual SIM (Nano-SIM, dual stand-by)
Display Type IPS LCD capacitive touchscreen, 16M colors
Size 5.5 inches, 83.4 cm2 (~71.1% screen-to-body ratio)
Resolution 1080 x 1920 pixels, 16:9 ratio (~401 ppi density)
Platform OS Android 7.1.1 (Nougat), upgradable to Android 8.0 (Oreo)
Chipset Mediatek Helio X23
CPU Deca-core 2.3 GHz
GPU Mali-T880 MP4
Memory Card slot microSD, up to 256 GB (dedicated slot)
Internal 64 GB, 4 GB RAM or 32 GB, 3 GB RAM
Camera Primary Dual: 13 MP (f/1.7, PDAF) + 5 MP (depth sensor), dual-LED dual-tone flash
3.5mm jack Yes
Bluetooth 4.2, A2DP, LE
GPS Yes, with A-GPS
Radio FM radio
USB microUSB 2.0, USB On-The-Go
Features Sensors Fingerprint (rear-mounted), accelerometer, gyro, proximity, compass
