Help how long does the mate 2 takes for charging from 0 % ?
Supposedly the charge time for normal usage is 2.5 hours from 0% to 100% but you can cut that in half or better if you turn it off while charging. On top of that, it starts warning you about the battery under 20% and blinks red constantly below 10%, so you're rarely charging from 0% anyways.
Also, for a quick charge while it is on, turn off wifi.
