Help How many charge cycles does a modern Android smartphone have in average?
I've heard a lot of "charge cycles" when I was searching battery tips. But when I googled it, the only product that gave information about it's charge cycles was MacBook. No other product was shown there.
So, in average, how many charge cycles does a modern day Android Smartphone have? In MacBook, it was 500 untill about 2009 and they improved it, made it 1000. So I think battery manufacturers made a big improvement on that. If that happened, probably Android smartphone batteries have that as well.
Do you know anything about this? Because there's a lot of difference between 500 and 1000. 500 means in average I would have to change my battery in 1,5 years whereas in 1000 it's up to 3 years.
If you have any information, please let me know. Thank you.
In your previous thread @chanchan05 gave a detailed description of battery charging cycles:
http://androidforums.com/threads/non-removable-batteries-why.1112492/#post-7477895
Seems like battery post is needed again with how to make batteries last longer than 2 years.
Anyway the gist is, basically, batteries work by ion movement, and like a machine, these ions wear out over time due to use. And similar to machines, heavy use wears them out more. You're more likely to break an engine by running it for 1 day at max rev, than running it over a month at half capacity. The smaller the depth of discharge, the lower the wear. Lab tests have concluded that when you constantly discharge from 100 to 0, it allows you betwrrn 300-500 charge cycles before it starts to break down and not hold charges. More specifically, when you reach that magic number your battery can only hold 75% of it's original charge. That's typically 1-2 years of use if you charge once a day. And heavy abusers charge more than once a day, so that decreases the time span to however many weeks it takes them to reach 500 charge cycles.
Now, the increase in charge cycles is exponential, not arithmetical. So a depth of discharge to 50 before recharging will not give you 600-1000 charges. Rather it will give you 1200-1500 charge cycles. Mathematically, draining a 3600mah to zero for 300 charges gives you 1080000mah to burn through however short your battery life will be. On the other hand, using only 50% of the battery before recharging gives you 2160000mah to burn through before it expires after at least 1200 charge cycles. In other words, it stored twice more power for you to use. If you say, charge once every 24hrs, going always from 100 to 0 gives you at least 300 days. Recharging twice a day at 50% gives your battery at least 600 days of use before battery capacity deteriorates noticeably. Discharging to 75% before recharging actually gives you 2000-2500 charge cycles, making it even longer.
Basically the point is, always plug the phone in when given the chance. Don't wait for 50%, or whatever. 40% is an arbitrary number actually, not sure why it's chosen. Also, this is why one of the choices to auto activate power saving in the S7 is at 50%, so that it keeps the battery up as close to 50% as possible when you get the chance to plug in.
As for charging to 80%, this is because partial charge is better than full charge for lithium ion batteries. The ions are placed on stress to hold charges. Maximum stress is at 100% charge. And like everything else, stuff tends to break more. So not running it to 100% all the time will reduce overall stress experienced and increase the time before deterioration occurs. Personally I charge to 90%, and discharge to 40% or above. That's a 50% depth of charge, so that's good for up to 1500 charge cycles, plus whatever number of cycles the decrease in max stress gives me.
However, note that environmental temperatures also play a role in battery longevity.
Edit:
Hmm. Seems that I need to edit this. It's actually the depth of discharge that's important, not the percentage level left in the battery. Discharging from 100-50 will have the same effect on number of charge cycles as discharging from. 90-40, since both are a 50% discharge depth. They 90-40 discharge does have the advantage of having less full ion wear.
