Link download : copi cand past to your brower rom.miui.com/en/download/view/id/359331#top
CHANGES:
- The SystemUI Mod: Add screen lock button, display the battery% icon.
- Fix brightness adjustment bar: It displays work mode.
- The default icon style Razr. If using LG Home is the theme you can choose if you like Prada => This is actually so that you can experience the many 3rd party Launcher from which the projection is not difficult to see the black-white Icon Prada.
- Integrated Razr Launcher: To use it you on the "Settings home screen -> Choose the home screen: And that is the choice in the Launcher"
- Fix the Motorola Razr Launcher to suit the format of Prada: This step is the most complicated because of the two-dimensional launcher is not playing with each other
- Fix the Qslide and Power Control widget to suit Raz Launcher
- Update some system applications
- Fix application HomeSelector to show it to you, choose Icon Launcher
- Add some basic app: Earth, MiniDict, TapatalkHD, UC Browser, ...
Please send to me any report about errors, bugs..etc..that can help me make this room perfect.Thanks
