Help How much does the eeepad charger weigh?
chiko930
Does anyone know whether it is the size of a normal laoptop cbarger or have they made it smaller to keep the overall weight down?u
It's a little bigger than a phone charger. It's a USB cable with a special end which goes onto the tablet or keyboard. Then the USB cable plugs into the little box which plugs into the wall.
My only issue is that the cable is only about 2.5ft long, doesn't reach from my wall to my bed- so for $9 I got a USB 3 extension cable. (older ones don't work)
