Sorry, Im confused you said "is possible achieved" followed by " not a solution". Is it safe to assume that mean its possible with some devices but it doesn't work with your device.
It might just be Googles policy changes with Accessibility Services on newer OS (maybe). I do know root apps like volume slider and kinetic scroll are no longer able to use Accessibility Services on Nugget or higher. It may also include Greenify and Tasker. Google position is the the services were intended to help people with handicapping disabilities. Personally, I prefer the old policy and the ability to use the app above. I just felt you should be aware of this as Accessibility Services deny drag drop mouse coordinates access. My knowledge of what your trying to do is of familiarity. Best of luck
