Root How to- A2SD?
BrianJB
Does anyone know how to flash/terminal emulator everything for a2sd? I am thinking about flashing a new rom and they say you should flash this to free up internal memory.
I don't even know where to get A2SD, but if someone could point me to everything I need?
And if I am correct, would I flash the rom?, then in the same session flash a2sd?. Then once the phone boots do whatever needs to be done in terminal emulator?
Thanks for the help!
Some roms have it built in. Lets start with what rom you are looking to run.
Here is the link to the Dark Tremor A2SD thread on XDA.
Roms have to be set up to use A2SD and this being a Work In Progress with know issues, I doubt that it is set up for that. You can try it. Follow the directions in the link I gave you to download it and get your sdcard partitioned.
Top
