How to Access Wireless Network in Android 4.0 Via PC
dars1987
Hi All...
i have installed android 4.0 OS on my PC. it installed properly and working much fi9.. with keyboard and mouse ... with normal user interface but there is just only a problem is that i cant access LAN or internet from that PC on which i have installed android 4.0, i think OS can 't establish connection with LAN card. So i tried USB network Adapter but still facing same problem ... is there any alter way to access LAN or internet ???? and also is there any driver available for same I'm using D-link DWA-125 USB wireless network adapter....suggestion from experts a appreciable......:) ...thanking ALL
I have Installed Android 4.0 On my PC, As Installed Sucessfully but can not access LAN through Ethernet Card or Wireless Ethernet Adapter,
Is there Any Other Way to Access LAN from Android OS Via PC
Any Drivers Suggestion Are welcome.:):)
You'll need to find a driver for that D-Link card before Android can make use of it.
Have you looked around for *nix drivers for that card? May (or may not) help.
thnxx...4 suggestion i have googled abt ur suggestion bt not get success to find any match of that....can u provide link ???
