How to automatically launch hotspot like Tasker?
I used to use Tasker, I tried it on this phone and it launches and turns on hotspot but devices do not connect and stay stuck in obtaining IP address. Only works when I launch manually.
Hello, not sure if this helps but try using automate and download/create specified flow.
Also. Can you name a condition, that turns on automatically hotspot? Is it something like time baisis? Or what?
I normally try
When Connected to Bluetooth on car enable hotspot
When disconnected from Bluetooth on car disable hotspot
Thanks I will give it a try.
The message from the Tasker author ...
... Thom
