Help How to block a phone number from texting me
AppleUser
On MetroPCS, Galaxy S5, Android 4.4.2: Is there a way to block an annoying phone number who texts way too often?
Thank you so much!! When blocking a phone number:
1, Does it apply only to messages ?
2. Does the sender get a message back ?
3. Will I ever know the text was rejected ?
As per your original post and thread title, my reply is for blocking texts in Messaging. No message is sent to the sender. You will not know a text has been sent. These answers are carrier dependent.
If you wish to block calls, go to the contact in your address book... Menu (3 dots) > Add to Auto reject list
All calls will then go automatically to your voicemail, if set up.
Thank you again, Ironxxx.
