Hi,
I am using Android composite GridView and it is highlighted in default orange color.
Below is the xml which i used to show GridView but what is the attribute i have to add to my own color for highlighting the Grids
android:gravity="center" android:background="#FF696969"/>
Please provide a sample code on doing this.
xml version="1.0" encoding="utf-8"?>
<GridView xmlns:android="http://schemas.android.com/apk/res/android"
android:id="@+id/gridview"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
android:numColumns="auto_fit"
android:verticalSpacing="40dp"
android:horizontalSpacing="40dp"
android:columnWidth="90dp"
android:stretchMode="columnWidth"
