Apps How to compile a kernel module to Android Linux Kernel
neutyz
Hi,all!
I'd like to compile a kernel module to Android Linux Kernel. But I donnot know how to build the Makefile for the module.
Here is my Makefile,and /home/tyz/0728 is source code dir of android:
obj-m= test_k.o
KERNELDIR= /home/tyz/0728/kernel/
CROSS_COMPILE= /home/tyz/0728/prebuilt/linux-x86/toolchain/arm-eabi-4.2.1/bin/arm-eabi-
CC= $(CROSS_COMPILE)gcc
PWD= $(shell pwd)
modules:
$(MAKE) -C $(KERNELDIR) M=$(PWD) modules
modules_install:
$(MAKE) -C $(KERNELDIR) M=$(PWD) modules_install
clean:
rm -rf *.o *~ core .depend .*.cmd *.ko *.mod.c .tmp_versions
rm Module.symvers
After make modules,I get nothing but errors :
make -C /home/tyz/0728/kernel/ M=/home/tyz/NetBeansProjects/test3GNetlink modules
make[1]: Entering directory `/home/tyz/0728/kernel'
ERROR: Kernel configuration is invalid.
include/linux/autoconf.h or include/config/auto.conf are missing.
Run 'make oldconfig && make prepare' on kernel src to fix it.
WARNING: Symbol version dump /home/tyz/0728/kernel/Module.symvers
is missing; modules will have no dependencies and modversions.
CC [M] /home/tyz/NetBeansProjects/test3GNetlink/test_k.o
cc1: error: unrecognized command line option "-m64"
cc1: error: unrecognized command line option "-mno-red-zone"
cc1: error: unrecognized command line option "-mcmodel=kernel"
cc1: error: unrecognized command line option "-maccumulate-outgoing-args"
cc1: error: unrecognized command line option "-mno-sse"
cc1: error: unrecognized command line option "-mno-mmx"
cc1: error: unrecognized command line option "-mno-sse2"
cc1: error: unrecognized command line option "-mno-3dnow"
make[2]: *** [/home/tyz/NetBeansProjects/test3GNetlink/test_k.o] error 1
make[1]: *** [_module_/home/tyz/NetBeansProjects/test3GNetlink] error 2
make[1]: Leaving directory `/home/tyz/0728/kernel'
make: *** [modules] error 2
what should I do ?Thanks!
