HOW TO: Convert PDFs to Aldiko Books
talktoanil
I found this application for PC, Mac and Linux called Calibre. This application will converyt all of your .PDF into .ePUB files. So here is the process i used to convert Zombie Survival guide into an Aldiko book.
1. Install Calibre. Tell it where you want the converted files output to.
2. Select the Google phone setting in Calibre for conversion.
3. Up in the top left corner of Calibre, there is a green button that you use to add your PDFs. You can either go one at a time and convert them, or you can add all of your PDFs and convert them in a batch.
4. Mount your phone and navigate to your eBooks section on the SD card. Add a new folder called import.
5. Now in another explorer window, navigate to your Ebook output folder that you designated at the install of calibre.
6. copy your book over from your computer to your phone. If you want to conserve space, you can also open up the books file and delete the original PDF. Make sure you leave the .Epub in there though
7. Lastly, unmount your phone, open up aldiko, press the menu softkey and select import. This will scan your import folder and import any books you have put in there. (Dont worry if it takes a long time, its just doin its thing.)
Hopefully this helps a lot of people out. i know im going to be reading more.
Source : HOW TO: Convert PDFs to Aldiko Books - Droid Forum - Verizon Droid & the Motorola Droid Forum
Legal and Free Download link for Calibre: calibre - Download calibre
  • Like
Reactions: OFI
Hopefully this turns out better than another app I tried which seemed to break Aldiko and gave a corrupted book name and no cover.
Thanks, I intend to convert several car manuals :)
keep everything at default and try...works simply awesome here. upload your PDF and i will try it.
