Help How to copy Contacts to Ideos?
saadzr
Hey
I was using Nokia E51 and now using Ideos. I need to transfer my contacts from E51 to Ideos. Can you plz help me or suggest me how to copy directly from E51 to Ideos?
I have approx 1800 contacts.
Your answer will he highly appreciated.
The simplest way is to connect to gmail thru your e51 and let t sync your contacts. Then switch phone off, switch on your android phone and use gmaill app. Your contacts will sync into your android.
The harder way is to connect e51 to Nokia PC Suite on your pc. Pc Suite came with the phone and is also available as a free download. Sync your contacts, then tell PC Suite to export the contacts in vcard format. Then login to gmail from your pc. Click contacts and import the file that PC Suite had created. After google has imported your contacts use the gmail app in your android phone to connect to google and your contacts will be auto-synced.
Dear SSaigol, pls help with elaborating your advise... i also have an e51 and want to shift to Android, & IDEOS is the affordable solution at this moment. how exactly can i sync contacts with Gmail?
regards
Ali
