tiho_bg
Hello,
I would like to use chilkatsoft and android studio for creation ssh connection.
I've implemented the library successfully but I have an error during ssh connect.
Here is my code:
package com.example.mobile4;
import androidx.appcompat.app.AppCompatActivity;
import android.os.Bundle;
import android.widget.TextView;
import com.chilkatsoft.*;
public class MainActivity extends AppCompatActivity {
@override
setContentView(R.layout.activity_main);
TextView tv = new TextView(this);
CkCrypt2 crypt = new CkCrypt2();
// Display the version of the CkCrypt2 class
tv.setText(crypt.version());
setContentView(tv);
CkGlobal glob = new CkGlobal();
boolean success = glob.UnlockBundle("Anything for 30-day trial");
if (success != true) {
System.out.println(glob.lastErrorText());
System.out.println("Error 1");
return;
int status = glob.get_UnlockStatus();
if (status == 2) {
System.out.println("Unlocked using purchased unlock code.");
else {
System.out.println("Unlocked in trial mode.");
// The LastErrorText can be examined in the success case to see if it was unlocked in
// trial more, or with a purchased unlock code.
CkSsh ssh = new CkSsh();
// Connect to an SSH server:
String hostname;
int port;
// Hostname may be an IP address or hostname:
hostname = "100.50.10.150";
port = 22;
success = ssh.Connect(hostname,port);
System.out.println(ssh.lastErrorText());
System.out.println("Error 2");
return;
static {
System.loadLibrary("chilkat");
The errors are:
12/21 13:36:09: Launching 'app' on HUAWEI YAL-L21.
Install successfully finished in 2 s 673 ms.
$ adb shell am start -n "com.example.mobile4/com.example.mobile4.MainActivity" -a android.intent.action.MAIN -c android.intent.category.LAUNCHER
Connected to process 22884 on device 'huawei-yal_l21-BQL0219C04002062'.
Capturing and displaying logcat messages from application. This behavior can be disabled in the "Logcat output" section of the "Debugger" settings page.
D/HwFrameworkSecurityPartsFactory: HwFrameworkSecurityPartsFactory in.
I/HwFrameworkSecurityPartsFactory: add HwFrameworkSecurityPartsFactory to memory.
E/BehaviorCollectManager: Fail to acquire dataAnalyzerService...
I/HwApiCacheMangerEx: apicache path=/storage/emulated/0 state=mounted key=com.example.mobile4#10209#256
need clear apicache,because volumes changed,oldCnt=0 newCnt=1
I/HwApiCacheMangerEx: apicache path=/storage/emulated/0 state=mounted key=com.example.mobile4#10209#0
need clear apicache,because volumes changed,oldCnt=1 newCnt=1
I/HwPartIawareFactory: add android.common.HwPartIawareFactoryImpl to memory.
I/AwareBitmapCacher: init processName:com.example.mobile4 pid=22884 uid=10209
E/AwareLog: AtomicFileUtils: readFileLines file not exist: android.util.AtomicFile@744d6ca
I/ActivityThread: finishPreloaded preloadStatus 0
V/ActivityThread: callActivityOnCreate
I/DecorView[]: old windowMode:0 new windoMode:1
I/OverScrollerOptimization: start init SmartSlideOverScroller and get the overscroller config
W/example.mobile: Accessing hidden method Landroid/view/View;->computeFitSystemWindows(Landroid/graphics/Rect;Landroid/graphics/Rect
Z (greylist, reflection, allowed)
W/example.mobile: Accessing hidden method Landroid/view/ViewGroup;->makeOptionalFitsSystemWindows()V (greylist, reflection, allowed)
I/System.out: Unlocked in trial mode.
ChilkatLog:
UnlockBundle:
DllDate: Aug 28 2021
ChilkatVersion: 9.5.0.88
UnlockPrefix: NONE
Architecture: Little Endian; 64-bit
Language: Android Java
VerboseLogging: 0
component: Global
unlockCode: Anything for 30-day trial
regKeyUnlock:
product: ChilkatBundle
hcCurDate: Tue, 21 Dec 2021 13:36:13 +0200
hcExpire: 11/2021
Component successfully unlocked using trial key
--regKeyUnlock
Success.
--UnlockBundle
--ChilkatLog
I/System.out: ChilkatLog:
Connect_Ssh:
UnlockPrefix: Anything for 30-day trial
VerboseLogging: 0
connectInner:
hostname: 100.50.10.150
port: 22
sshConnect:
connectSocket:
connect_ipv6_or_ipv4:
ai_family: 2
ai_socktype: 1
ai_protocol: 6
socketErrno: 13
socketError: Permission denied
Failed to create socket for connecting.
--connect_ipv6_or_ipv4
ai_family: 2
ai_socktype: 1
ai_protocol: 6
socketErrno: 13
getAddressInfo:
Failed to get host address info. (4)
gai_error: 3
hostOrIpAddr: 100.50.10.150
port: 22
Retrying DNS lookup...
gai_error: 3
port: 22
--getAddressInfo
getAddressInfo failed.
getAddressInfo:
gai_error: 3
port: 22
gai_error: 3
port: 22
--getAddressInfo
--connectSocket
Failed to establish initial TCP/IP connection
port: 22
--sshConnect
--connectInner
Failed.
--Connect_Ssh
--ChilkatLog
Error 2
D/ActivityThread: add activity client record, r= ActivityRecord{24a8ece token=android.os.BinderProxy@90e5cb1 {com.example.mobile4/com.example.mobile4.MainActivity}} token= android.os.BinderProxy@90e5cb1
I/HwPartMagicWindowFactory: add android.common.HwPartMagicWindowFactoryImpl to memory.
I/HwPartPowerOfficeFactory: add HwPartPowerOfficeFactoryImpl to memory.
D/InputEventReceiver: dispatchInputInterval 1000000
I/RmeSchedManager: init Rme, version is: v1.0
D/HiTouch_PressGestureDetector: onAttached, package=com.example.mobile4, windowType=1, mHiTouchRestricted=false
I/FrameFlow: FrameFlowInit app is not supported by frameflow solution
I/iGraphics: [0020080c] pn: com.example.mobile4, p: 22884
[0030080c] no spt app: com.example.mobile4
D/mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, EGLBoolean) returns 0x3000
W/Gralloc3: mapper 3.x is not supported
I/HwViewRootImpl: removeInvalidNode jank list is null
D/DecorView: showOrHideHighlightView: hasFocus=true; winMode=1; isMrgNull=true
W/InputMethodManager: startInputReason = 1
W/InputMethodManager: startInputReason = 5
I/AwareBitmapCacher: init lrucache size: 2097152 pid=22884
W/InputMethodManager: startInputReason = 8
W/IInputConnectionWrapper: getExtractedText on inactive InputConnection
W/IInputConnectionWrapper: getTextBeforeCursor on inactive InputConnection
E/RtgSchedManager: endActivityTransaction: margin state not match
W/libEGL: EGLNativeWindowType 0x6f9864b450 disconnect failed
I/ActivityThread: Handle window ActivityRecord{24a8ece token=android.os.BinderProxy@90e5cb1 {com.example.mobile4/com.example.mobile4.MainActivity}} visibility: false
D/DecorView: showOrHideHighlightView: hasFocus=false; winMode=1; isMrgNull=true
D/RtgSched: resetRtgSchedHandle failed enable:0
D/ZrHung.AppEyeUiProbe: not watching, wait.
I/AwareBitmapCacher: handleReleaseCache: pid=22884
Here is my code:
@override
setContentView(tv);
return;
if (status == 2) {
else {
String hostname;
int port;
port = 22;
return;
static {
The errors are:
ChilkatLog:
UnlockBundle:
UnlockPrefix: NONE
VerboseLogging: 0
component: Global
regKeyUnlock:
hcExpire: 11/2021
--regKeyUnlock
Success.
--UnlockBundle
--ChilkatLog
Connect_Ssh:
VerboseLogging: 0
connectInner:
port: 22
sshConnect:
connectSocket:
ai_family: 2
ai_socktype: 1
ai_protocol: 6
socketErrno: 13
ai_family: 2
ai_socktype: 1
ai_protocol: 6
socketErrno: 13
getAddressInfo:
gai_error: 3
port: 22
gai_error: 3
port: 22
--getAddressInfo
getAddressInfo:
gai_error: 3
port: 22
gai_error: 3
port: 22
--getAddressInfo
--connectSocket
port: 22
--sshConnect
--connectInner
Failed.
--Connect_Ssh
--ChilkatLog
Error 2
