How To Delete Blank Home Pages
I have an Honor 6X and need help deleting unwanted blank home pages. I have 4 pages with different apps on them, however, there are 2 blank pages which I want to remove and get off my home screens.
I can do the long press on the screen, but there is NO trash or Delete Icon on the top of the screen, only an icon which looks like “home”.
After the two finger pinch do you get a thumbnail view of your home pages as described in the link I attached?
If you do have you tried longpressing an empty page?
At that point on my HTC M9, 'Remove' appears at top right of the screen and the empty page can be dragged and dropped onto it.
Could you post a screenshot of what you see after the 'pinch'?
I have tried the “Long Press” or the “Two Finger Pinch” methods do not work. Neither of them display or show a Trash Can Icon or Delete Icon in order to remove or delete all these blank pages.
A few thoughts :-
How long have you had the device.
Any recent OS updates.
I assume this the first time you've tried to remove home pages.
Something you could try is a 'wipe cache partition'. It's a procedure that I have carried out on my HTC M7 and M9 over the last 4 to 5 years whenever I get weird glitches and has been very successful. It doesn't affect data or settings.
I have got into the habit of doing it fairly regularly just to keep things running clean. It takes a couple of minutes to do.
Did you download any launchers or are you using the original one?
Hey, it's been long, but frankly I had that problem and wanted to share some help. I use honor 8 lite currently and somehow managed to get about 10 useless home pages, none of above tips work, so I figured it out myself. Here it is:
1. Go to settings
2. Search from home screen style
3. Change your style to that other one.
4. You might have to leave app, then start it again and change back to normal.
5. If there is still any pages you don't need you can now delete those!
Hope this helps anybody :)
- Jacob
