Help How to Delete Custom Device Vibrations
skorpien
Hi all, hope the community can answer a simple question.
Was playing around with my Galaxy S3 and stumbled upon the Device vibration submenu. I created a custom vibration (just because I could), but now I can't figure out how to delete it.
I contacted Samsung's live chat support and they said there's no way to delete them. Worse yet, instead of overwriting the old one, it creates a duplicate if you use the same name when saving new ones. Any help would be appreciated.
Thanks in advance.
Settings / Sound / Device Vibration / longpress on the custom vibration you want to delete, choose Delete or Rename from the popup menu.
