Help How to disable Easy Voice Recorder from displaying info on locked screen?
spman
Hi,
After I press Record on Easy Voice Recorder app, then I leave it in the background running. When I lock the phone, a message displays Easy Voice Recorder appears (see screenshot) on the main locked screen.
How can I prevent/disable the Easy Voice Recorder message?
I do not want any message of Easy Voice Recorder to be displayed.
I am using Samsung Galaxy S4, Android 5.0.1, Easy Voice Recorder 1.8.1
Thanks a lot.
Isn't in the settings for notifications, you can choose which notifications show up in the lockscreen. Just remove Easy Voice Recorder from there.
Can you please teach me the steps to choose which notifications show up in the lockscreen?
Go to settings>sound & notification>notification>app notification>scroll down to the required app tap on it then tap on "Block" button. (Never show notifications from this app.)
