Root How to disable startup sound on Rooted phones and edit boot up pictures
c627627
Device: Motorola CLIQ MB 200 Android 2.1 phone [Rooted] Blur_Version.2.1.5.MB200.T-Mobile.en.US
Which file needs to be edited to disable the annoying startup up boot sound? I would rather edit then use an app.
Using Droid Explorer I found that this zip file contains the boot up animation:
/system/media/bootanimation.zip
The zip file contains a series of .png files which I assume can be simply replaced?
But you can use Droid Explorer from your PC to only copy files from phone - not write files TO phone. How do I mount the phone as read and write so I can simply copy-paste files from PC?
Rooted phones can be edited. Use ES File Explorer app. Go to its settings > CHECK: Root Explorer and Mount File System > to be able to copy-paste files from SD card to the phone system.
Don't forget to dismount the File System when finished for security reasons.
Renaming /system/media/bootanimation.zip gets rid of the default Motorola and default Cell carrier animation and the Android logo changing colors can be seen instead at boot up.
Renaming /system/media/audio/notifications/OnTheHunt.ogg is the only way to get rid of the boot up sound.
