How to disable volume buttons when phone is locked?
Palchuhai
Hi guys, i have problem with volume buttons. When my phone is locked and I press lock button once then its possible to change volume. I want to change volume when its unlocked :(
Any solution?
Thanks
I don't know of a way to prevent the volume buttons from controlling the volume while the phone is unlocked. I think that was an intentional design to let you quickly silence your phone without having to pull it out.
