How to Find a High Speed Download for Stock Samsung Firmwares
ciresiuol123
How to Find a High Speed Download for Stock Samsung Firmwares:
-Go to http://www.sammobile.com/firmwares/
-Search for your device by model number... This can usually be found under the battery or by going to Settings>About Phone/Device and scrolling down until you see the #... It will usually consist of 2 letters, a hyphen, then 3-6 more letters/numbers (for example, mine is SM-G386T)...
-Find the newest (if you want the newest) firmware from your region and tap on it to go to the download page, but don't download...
-Look for the "PDA" in the description of the file (mine is G386TUVU1AOH3) and select it, then copy to clipboard...
-Go to your favorite search engine (https://duckduckgo.com) and paste the PDA, then search...
-Find one that doesn't require a paid account for fast download speeds and download your file... https://www.androidfilehost.com is a great, popular result with amazing download speeds... You can really just go search there for your device and most likely you will find a stock firmware, although not always the newest, but they will update since the device will no longer be rooted...
This will work for other devices as well, but you will need a different "slow" source...
