If the photos was stored on memory card, just take-out the memory card, place it to computer card reader (or connect the phone to computer in mass storage mode, but it's very slow then) and try to run some undelete program on the card disc. Or if it was stored on internal memory accessible as USB massstorage disc, connect it as USB drive and run undelete on the storage.
Important thing is not to write to card after deleting the photos, but if no program wrote to the memory after deletion, the probability to restore files is really high.
whenever you loss your data from any of the storage device never rewrite on device if you do so then you will loose your data. Its better to use any photo recovery software for recovery purpose. Before buying any photo recovery software just check weather it will recover your photo or not and for checking it you need to choice those softwares which can give you the preview option of your lost files before buying it.
