Help How to format my micro SD card on my Asus tablet?
jo69
May 29, 2013
448
56
Am trying to format the sd card on my android tablet.
As for some reason I now have duplicate files. And when I delete one they both go.;)
Googled and it says unmount it and a menu comes up saying format.
Well on mine all I get is unmount and then mount.
Can you help?
It just says this......
Upvote 0
Thank you I had found that before But was not confident enough to do it
But here's what I have done, put the micro SD card into a card reader and plugged it into my pc.
Did what I 1st thought of but was not sure.. right clicked on it in my computer and click format
That has worked so am now replacing it in my tablet and fingers crossed hopefully no more duplicate files.
Everything else I tried said the card was write protected Why would that be?
  • Like
Reactions: AMOCO
Upvote 0
BEST TECH IN 2023
Smartphones
