How to get a transparent S Planner on Edge 7 ?
Darnads
Hello,
I've recently had to return the Note 7 (due to the recall) and I've chosen the Edge 7 as a replacement.
On the Note 7, I could put a S Planner widget and when placing the widget there was a configuration cog that when clicked I could set the background transparency for the S Planner full page widget - effectively just seeing the month, appointments, and my background nicely.
Now that I've swapped phones for the Edge 7, the S Planner widget only has one option - it's a full page widget S Planner with a white background and looks terrible.
My questions are two fold;
1. How do I get the numerous S Planner widgets. I used to be able to select different sizes such as one liner, 2x3 or 4x5 (full page one) which I currently have as my only option.
2. How can I get the full page one to have a transparent background? I can't seem to find it in the options anywhere
Those options were exclusive to the Note 7 on release as it come with Samsung's next gen UI: Grace UX. The S7 Edge still has the older TouchWiz. Samsung promised back in September that Grace UX will come to the S7 phones with the Nougat update.
