ive always had two days of charge out of my phone with 3G (48 hours) on and just over three days (60 hours) when i force it too 2G but i have been charging my phone over night and leaving it plugged in until i leave for work in morning. FYI Wifi, Bluetooth, GPS are off.
However just last night I charged a quick charge from 40% to 100% 2-3 hours i think it was plugged in, unplugged went to bed, woke up this morning and its flat 4%. So in 8 hours its gone flat from me not even turning on the screen, and i think i know the problem.
The problem seems to be when it says 100% it aint nowhere near 100% must be an error or something in android measuring the battery level or the battery only charges with trickle charge and not a fast charge e.g. 2 hours didn't do squat even though the manual say 3 hours it cant be correct
Leave your phone charging overnight for 8 hours and if your battery is ok you will get two days with light usage. E.g each day 5 texts, 3-4 calls (not 20 min calls or anything like that just 5 min ones) and a small amount of browsing with 3G on. Cause thats what i get.
Anyway just thought you should try it before buying a new battery cause i dont feel like i need to, im happy with 2 days. I've seen a lot of people on this forum and around the net not even getting one day with no usage and that is what happens to me when i dont charge for 8 hours.
Good luck
Good luck
