Cosmin Telescu
I want to implement an app which measures the quality of the WiFi signal from an indoor environment. From my research I found that the best way to get an accurate measurement is not to get only the RSSI but instead to use the SNR (Signal to Noise Ratio).
How can I obtain the noise level from the Android SDK? As I heard, there is no API available for this. However, I've found a method which provides the SNR (getEvdoSnr()). Unfortunately, this one works only for a GSM/CDMA signal and not for a WiFi connection.
Is anything possible to calculate the SNR in Android? I believe that's doable because I've found an app on Play store (called WiFi SNR) which successfully measures this ratio.
NOTE: The Android ScanResult doesn't provide the noise level, even if it's specified in the official documentation:
Describes information about a detected access point. In addition to the attributes described here, the supplicant keeps track of quality, noise, and maxbitrate attributes, but does not currently report them to external clients.
