How to I get android studio sdk to sync with Gradle? (Help)
I decided to take up learning android development very recently but I'm stuck before I can get started! If anyone has any suggestions on how to fix this issue I would really appreciate it. Thank you.
For reference here is one of the videos I used for troubleshooting and this didn't work. (Chances are I might have made a mistake)
I'd suggest to just be connected to the internet and use SDK manager to update/install required Android SDK's.
Try to Sync gradle again and follow the instructions that appear when it fails. Android Studio can automatically download required files for syncing.
I also think so. Use the SDK Manager.
