How to import a class SavedStateHandle
mcpixel
I have another big problem. I dial the SavedStateHandle and press alt+enter, I see only one useless item and nothing more!
I registered it in dependencies and synchronized gradle:
Code:
def lifecycle_version = "2.0.0"
    // ViewModel and LiveData
    implementation "androidx.lifecycle:lifecycle-extensions:$lifecycle_version"
    // alternatively - just ViewModel
    implementation "androidx.lifecycle:lifecycle-viewmodel:$lifecycle_version" // For Kotlin use lifecycle-viewmodel-ktx
    // alternatively - just LiveData
    implementation "androidx.lifecycle:lifecycle-livedata:$lifecycle_version"
    // alternatively - Lifecycles only (no ViewModel or LiveData). Some UI
    //     AndroidX libraries use this lightweight import for Lifecycle
    implementation "androidx.lifecycle:lifecycle-runtime:$lifecycle_version"
    annotationProcessor "androidx.lifecycle:lifecycle-compiler:$lifecycle_version" // For Kotlin use kapt instead of annotationProcessor
    // alternately - if using Java8, use the following instead of lifecycle-compiler
    implementation "androidx.lifecycle:lifecycle-common-java8:$lifecycle_version"
    // optional - ReactiveStreams support for LiveData
    implementation "androidx.lifecycle:lifecycle-reactivestreams:$lifecycle_version" // For Kotlin use lifecycle-reactivestreams-ktx
    // optional - Test helpers for LiveData
    testImplementation "androidx.arch.core:core-testing:$lifecycle_version"
Code:
But it did not help. In general, nothing helps as if this class does not exist at all! Help
  • 2019-07-30_00:03:57.jpg
Make sure you have this line in gradle file.
Java:
implementation 'androidx.lifecycle:lifecycle-viewmodel-savedstate:1.0.0-alpha01'
Add this in your gradle file and sync
Java:
