Apps How to include two prebuilt interdependent shared libraries into Android application using cmake
I want to include two shared libraries liba.so and libb.so into my android application. Where function of libb.so is called from function in liba.so.
I have a Java class which calls native JNI Function as,
package com.test.myapplication;
public class MainActivity extends AppCompatActivity {
static{
System.loadLibrary(a);
System.loadLibrary(b);
public native void testSample();
@override
setContentView(R.layout.activity_main);
testSample();
My JNI file is
#include"a.h"
extern "C" void JNICALL Java_com_test_myapplication_MainActivity_testSample( JNIEnv* env, jobject thiz) {
a_foo();
a.cpp file which is part of my library liba.so is
#include"b.h"
void a_foo()
/* ..... code .....*/
b_foo();
My b.cpp which is part of libb.so is
void b_foo()
I want to include liba.so and libb.so as librares and not as source into my application. Both the libraries are built using android-ndk independently.
Line System.loadLibrary(a); gives a runtime exception
java.lang.UnsatisfiedLinkError: dlopen failed: cannot locate symbol "b_foo" referenced by "/data/app/com.test.myapplication-yyA38UEBmsXvaqOY-hm_HQ==/lib/arm64/liba.so" when loading
