How to Install Xposed Framework for ZTE ZMAX PRO
How to install Xposed framework for ZTE Zmax Pro.
Needs TWRP recovery; possibly root but I cannot be sure.
1) Visit https://forum.xda-developers.com/xp...ess-xposed-t3388268/post67074423#post67074423 and download and install the Xposed-installer apk
2) Open Xposed and tap on install/update: Version 89 and pick install.
3) It should download and then proceeded to install it but it should fail.
4) Exit the app and open a file manager
5) Go to /storage/emulated/0/Android/data/de.robv.android.xposed.installer/cache/downloads/framework/xposed-v89-sdk23-arm64.zip and move the zip on your SD card.
6) Reboot into TWRP, and install the zip from there.
7) Reboot device and you're done. (Start up will take a little longer)
Be sure to do a nandroid backup with twrp before installing Xposed in case of loop. Easy on the system mods since firmware isn't dumped yet.
