Help How to lessen wakeup triggers?
tyrone910
Hi guys, I just want to ask how to lessen or stop wakeup triggers caused by apps? I installed Wakelock Detector and found out the the top 3 apps that cause wakeup triggers are Calendar Storage, Maps and Email. Can you please help me? Thanks.
For Maps, it's probably because you have it configured for high accuracy. Try setting it for cell tower triangulation only. << that may not be the exact wording, but something similar
For the others, if your device is rooted, install Xposed framework and the Amplify module.
