how to load flash player for kindle fire hd
  • Start date Start date
Welcome to AF!
Since Adobe Flash is no longer supported, you will have to side load the application. That requires finding an active download of Flash Player, downloading it to your Kindle, then running the installer from your download folder. This will require you to grant permission to the system to install non Play Store applications.
Hope that helps!
