Help How to Locate my Lost Phone
I've just lost my Samsung android phone. There's no battery left so it has turned off. GPS isn't enabled. I have already logged on using my Samsung ID on their website, but as there is no power let in the phone and I didn't enable remote access in my settings previously, this is no use. How can I trace and locate my phone?
You can't. The phone isn't emitting a signal for you to trace it in the first place. Also, did you even activate Find My Mobile on the phone? If not, then how about Android Device Manager? If also no, then just start looking for a new phone to buy.
I don't think I've done any of that :( thank you for the response!
