cyberforce
If you want to make FM radio works in Cyanogenmod 10.1.
There are the rules :>
1) Before you turn on the FM radio, you need to use music player to play songs. (to have FM radio with sound)
2) You must turn on the bluetooth before you turn on the FM radio.
3) After you turn on the FM radio and "seeking & playing" the channel, you can turn of the bluetooth.
4) If you wanted to switch channel. you must enable bluetooth.
5) If you hadn't turned on the FM radio before you turn on the bluetooth. you needed to reboot the device to make radio works again.
SO The steps is :
Turn on the music player => Play songs => Turn on the bluetooth => Turn on the FM radio => Seeking channels & start playing
OR :
Turn on the bluetooth => Turn on the music player => Play songs => Turn on the FM radio => Seeking channels & start playing
Then you can turn of the music player or bluetooth if you want.
but if you wanted to switch channel you must enable bluetooth again.
If it don't work. reboot the device. and do it again.
SO The steps is :
OR :
