how to make metro huawei m860 faster
  • Start date Start date
A
Android Question
Guest
i have a metro pcs huawei m860 (2.2.2) its very slow and i would like to fix that . Please & thank you
I just looked up the specs to the Huawei m860 and they seem to be a bit dated on what's offered out there today. Having said that, there are still a few things you may be able to do in order to help speed things up:
-Uninstall any apps that you aren't using. Too many apps on the phone can slow it down, specially considering the limited ram the phone has.
-Download a Cache cleaner such as App Cache Cleaner and run that app.
-Download System Panel to see what apps are using the most memory and delete those apps.
My only concern with all of this is if you phone can run those particular apps. Android 2.2.2 is a really dated version of android and some apps might not be compatible. If they aren't search for others they may be.
