Hi,
I love the application called Paper camera
( and I think most of you too).I am a novice and learning to develop rich UI android application.I am quiet fascinated the way the embedded buttons has been put into custom made UI(User Interface) for Paper Camera.Is it kind of theme being provided by Andorid.Just wanted to know or any direction that how can such a UI be made, what tools can be used to make it.Even 1 % of the info will be helpful in rewarding my research.I have been using Android API level 8 and some times going to the Adobe Flash Builder 4.5 to draw such UI using mxml.
How can we create our own art and embedd buttons , sliders in it.
Rgds and Thanks in advance.
Saurabh
( and I think most of you too).I am a novice and learning to develop rich UI android application.I am quiet fascinated the way the embedded buttons has been put into custom made UI(User Interface) for Paper Camera.Is it kind of theme being provided by Andorid.Just wanted to know or any direction that how can such a UI be made, what tools can be used to make it.Even 1 % of the info will be helpful in rewarding my research.I have been using Android API level 8 and some times going to the Adobe Flash Builder 4.5 to draw such UI using mxml.How can we create our own art and embedd buttons , sliders in it.
Saurabh
