1. You can always take a simple option like a SMS backup and resotre app instead of backup you can also open the .xml files and print them If you want to print directly from your phone.
2. You can also do the old school version of copying and pasting the text into an email you send to yourself and then print from a computer too.
3. Try out any cloud printing app but i am not sure how it works ..
