rohit_deshmukh11
I want to access the XML file from sdcard and i want to parse thar file. How ta access this file and pass it to Parse method?
package nextapp.websharing.util;
import java.io.IOException;
import java.io.InputStream;
import java.io.PrintStream;
import java.io.PrintWriter;
import java.io.StringWriter;
import java.util.ArrayList;
import java.util.List;
import java.util.Properties;
import javax.xml.parsers.DocumentBuilder;
import javax.xml.parsers.DocumentBuilderFactory;
import javax.xml.parsers.ParserConfigurationException;
import org.w3c.dom.DOMImplementation;
import org.w3c.dom.Document;
import org.w3c.dom.DocumentType;
import org.w3c.dom.Element;
import org.w3c.dom.Node;
import org.w3c.dom.NodeList;
import org.w3c.dom.Text;
import org.xml.sax.EntityResolver;
import org.xml.sax.InputSource;
import org.xml.sax.SAXException;
* A utility class which provides methods for working with a W3C DOM.
public class DomUtil {
* Entity resolver which throws a SAXException when invoked to avoid external entity injection.
private static final EntityResolver entityResolver = new EntityResolver() {
* @see org.xml.sax.EntityResolver#resolveEntity(java.lang.String, java.lang.String)
public InputSource resolveEntity(String publicId, String systemId)
throws SAXException, IOException {
throw new SAXException("External entities not supported.");
* ThreadLocal cache of <code>DocumentBuilder</code> instances.
private static final ThreadLocal<DocumentBuilder> documentBuilders = new ThreadLocal<DocumentBuilder>() {
* @see java.lang.ThreadLocal#initialValue()
protected DocumentBuilder initialValue() {
try {
DocumentBuilderFactory factory = DocumentBuilderFactory.newInstance();
DocumentBuilder builder = factory.newDocumentBuilder();
builder.setEntityResolver(entityResolver);
return builder;
} catch (ParserConfigurationException ex) {
throw new RuntimeException(ex);
* Creates a new document.
* @param qualifiedName the qualified name of the document type to be
* created
* @param publicId the external subset public identifier
* @param systemId the external subset system identifier
* @param namespaceUri the namespace URI of the document element to create
public static Document createDocument(String qualifiedName, String publicId, String systemId, String namespaceUri) {
DOMImplementation dom = DomUtil.getDocumentBuilder().getDOMImplementation();
DocumentType docType = dom.createDocumentType(qualifiedName, publicId, systemId);
Document document = dom.createDocument(namespaceUri, qualifiedName, docType);
if (namespaceUri != null) {
document.getDocumentElement().setAttribute("xmlns", namespaceUri);
return document;
* Retrieves a thread-specific <code>DocumentBuilder</code>.
* @return the <code>DocumentBuilder</code> serving the current thread.
public static DocumentBuilder getDocumentBuilder() {
return (DocumentBuilder) documentBuilders.get();
* Determines whether a specific boolean flag is set on an element.
* @param element The element to analyze.
* @param attributeName The name of the boolean 'flag' attribute.
* @return True if the value of the attribute is 'true', false if it is
* not or if the attribute does not exist.
public static boolean getBooleanAttribute(Element element, String attributeName) {
String value = element.getAttribute(attributeName);
if (value == null) {
return false;
} else if (value.equals("true")) {
return true;
} else {
return false;
* Retrieves the first immediate child element of the specified element
* whose name matches the provided <code>name</code> parameter.
* @param parentElement The element to search.
* @param name The name of the child element.
* @return The child element, or null if none was found.
public static Element getChildElementByTagName(Element parentElement, String name) {
NodeList nodes = parentElement.getChildNodes();
int length = nodes.getLength();
for (int index = 0; index < length; ++index) {
if (nodes.item(index).getNodeType() == Node.ELEMENT_NODE
&& name.equals(nodes.item(index).getNodeName())) {
return (Element) nodes.item(index);
return null;
public static String getPropertyElementValue(Element parentElement, String propertyElementName) {
Element childElement = getChildElementByTagName(parentElement, propertyElementName);
if (childElement == null) {
return null;
return getElementText(childElement);
* Retrieves all immediate child elements of the specified element whose
* names match the provided <code>name</code> parameter.
* @return An array of matching child elements.
public static Element[] getChildElementsByTagName(Element parentElement, String name) {
List<Element> children = new ArrayList<Element>();
children.add((Element) nodes.item(index));
return (Element[]) children.toArray();
* Counts the number of immediate child elements of the specified element
* whose names match the provided <code>name</code> parameter.
* @param parentElement The element to analyze.
* @return The number of matching child elements.
public static int getChildElementCountByTagName(Element parentElement, String name) {
int count = 0;
++count;
return count;
* Returns the text content of a DOM <code>Element</code>.
* @param element The <code>Element</code> to analyze.
public static String getElementText(Element element) {
NodeList children = element.getChildNodes();
int childCount = children.getLength();
for (int index = 0; index < childCount; ++index) {
if (children.item(index) instanceof Text) {
Text text = (Text) children.item(index);
return text.getData();
return null;
* Returns a new DOM from an <code>InputStream</code>.
* @param in an <code>InputStream</code> providing the XML source
* @return a DOM
public static Document load(InputStream in)
throws SAXException {
try {
Document document = getDocumentBuilder().parse(in);
in.close();
return document;
} catch (SAXException ex) {
throw new SAXException("Provided InputStream cannot be parsed: " + ex.toString());
} catch (IOException ex) {
public static void log(PrintStream out, String prefix, Document document) {
try {
out.println ("[" + prefix + "] --------------------------------------------------------");
StringWriter w = new StringWriter();
DomUtil.save(document, new PrintWriter(w), null);
String s = w.toString();
s = s.replaceAll(">\\s*<", ">\n<");
out.println(s);
ex.printStackTrace(out);
* @return a DOM
public static Document load(InputSource in)
try {
return document;
public static void save(Document document, PrintWriter w, Properties outputProperties)
DomTransform.transform(document, w);
* Sets the text content of a DOM <code>Element</code>.
* @param element The <code>Element</code> to modify.
* @param value The new text value.
public static void setElementText(Element element, String value) {
text.setData(value);
return;
Text text = element.getOwnerDocument().createTextNode(value);
element.appendChild(text);
public static Element setPropertyElementValue(Element parentElement, String propertyName, String propertyValue) {
Element propertyElement = parentElement.getOwnerDocument().createElement(propertyName);
if (propertyValue != null) {
propertyElement.appendChild(parentElement.getOwnerDocument().createTextNode(propertyValue));
parentElement.appendChild(propertyElement);
return propertyElement;
/** Non-instantiable class. */
private DomUtil() { }
