latinmaxima
Android Expert
Thanks to Joseph Mother and Inxane from SDX!
Root is required for this, and adb.
adb shell
mount -o remount,rw /dev/block/stl5 /system
cd /system
rm recovery-from-boot.p
cd /system/etc
rm install-recovery.sh
Then flash recovery like normal.
Quote form Inxane recovery thread. UPDATE: several users have noted that some things are broken, system doesn't format properly, factory resets will brick the phone, and other strange errors. as such I warn you all that this recovery has major flaws and that I will not be working on fixing those flaws. it is up to you to fix them! good luck!
Recovery mode is vol dn, talk, end
http://www.sdx-downloads.com/devs/inxane/intercept/recoveryv14.tar
make the following folders on your sd card (REALLY! YOU HAVE TO DO THIS FIRST!)
/sdx/updates
/sdx/zip
/sdx/backup
Recovery can now be used for flashing "update zips"
you can now make backups of your system and data, in case you want to get a little crazy with your phone (i need someone who hasn't done anything to their phone aside from flashing kernel and recovery to help me get a clean system backup so that we can provide a failsafe for other users)
you can potentially flash other kernels (when more start to crop up)
just be careful, and read as much as you can, this is both a powerful and dangerous tool.
Use the drivers here when you put the device into download mode (Vol Dn + End + Talk). Steps to flash
1. Download and install SWUpgrade for the moment from here, then install LouZiffer's patch.
2. Download the recovery and put it in C:\Program Files (Program Files (x86) if you are on 64 bit)\Samsung Electronics\SWUpgrade\Models\Binary. DELETE THE FILE ALREADY IN THERE OR YOU MAY PERMA-BRICK YOUR INTERCEPT
3. Start your Intercept in Download Mode (Vol Dn + Camera + End) and plug it into the computer. Install the driver that you can download at the top of this post.
4. Open SWUpgrade and walk through the steps.
5.
6. PROFIT!
Just sharing info for those looking.
For more discussion or news on this topic please visit intercept recovery [important features working!]
adb shell
cd /system
cd /system/etc
/sdx/updates
/sdx/zip
/sdx/backup
5.
6. PROFIT!
