How to record sound over bluetooth device?
Nickk40
I have a HTC One M7 mobile phone. And a Jabra clipper for sound, which connects with my phone using bluetooth. This works fine with for example Skype on my phone: it uses the microphone and ear plugs of the Jabra clipper.
However, it doesn't work when recording a video or sound. It then still uses the microphone from the phone and not from the Jabra clipper. But for the video I'm creating I need to stand too far away from my phone for it to record the sound (not too far though that bluetooth is unable to connect the two). This problem exists for example with these two apps: "Camera" and "Video Recorder" both of which are installed by default on the phone.
How can I record a video (if possible with these apps) that takes the sound from the paired Jabra clipper?
Update: A similar problem exists on my laptop using Windows 10 its "Camera" app. Someone describes this problem here. The solution suggested there, and which also worked on my laptop, is to disable other microphones except that of the Jabra clipper.
Perhaps this solution would also work on my phone...? Can anyone tell me how I could disable other microphones on my phone (i.e. the microphone built into the phone)?
