How to remove "Samsung Quad Camera" from watermark
I know how to customize the watermark on the A51.
Is there a way to remove the Samsung Quad Camera text from the water mark or has Samsung made it permanent and can only be removed by rooting?
Thank you
Try looking for the 'Watermark' option buried in the Camera app's Settings menu:
https://downloadcenter.samsung.com/...1115/SM-A515F_UM_EU_QQ_Eng_Rev.1.0_191206.pdf
(referred to in pg. 94)
Thanks for the reply. The page only states how to add a watermark.
I know how to do that and it works perfectly.
However, in addition to the text I specify, there is an additional line of text that reads, "taken with Samsung Quad Camera" and there doesn't appear to be a way to exclude it from the watermark.
Has Samsung made this a permanent watermark when watermarks are enabled? It doesn't appear if they are turned off.
Does anyone know if it's possible to enable watermarks without the Samsung text?
Thank you.
Thank you.
I believe that if you enable the watermark, the "Taken with Samsung Quad Camera" will display along with your customized text below. If you disable the watermark (toggle), all is gone. There's no way to remove the "Quad Camera" and use your own text only (bummer).
I have a Samsung S20FE and the watermark toggle is gone so no more watermark. Who needs them anyway, when you can just insert any text now (and I presume that is what Samsung thought so too thus removing it) :)
