How To Remove Wallpaper from Home Decor
I'm using Acer Liquid Metal (Froyo 2.2). I crop a picture and made it wallpaper using Home Decor app. But then i couldn't figure out how to delete it so i can make another wallpaper?...anybody HELP pls?
I don't know how that works in Home Decor, but what happens if you try to use a new picture?
i can use new picture..i can crop and make new wallpaper...but i do not know how to delete old one...not in device manual cos the home decor is an app...and can't find guide for this home decor
If you can't see the old one in Gallery, or on SD card under directory Home Decor, then you can assume that the system removes the old one when you make a new one.
i found it....there are 8 allocated spaces for your own wallpaper...to delete the old one simply bring it to the rightmost and then make a new wallpaper. the one on the rightmost will be deleted.
exactly right theskipper. if we want to Remove Wallpaper from Home Decor the one on the rightmost will be deleted. so we have to make it on the right side.
