A
Android Question
Guest
Hi, Ive got a Android CoreTab 7" Tablet with OS 4.1 JellyBean and its block i forgot the pattern and attempted multiple time therefore it got block now its asking me to sign in with my google account but when i put my correct information it says invalid password or username. the power and + volume does not do anything. Hope you can solve this problem. Thanks
More information: Product Name: CoreTab Tablet PC
Main Features: WiFi, strong signal with excellent receiving; thin & Compact Design; full aluminium alloy shell, ultra-slim
Production Configuration
Solution: Rockchip3066
Master Frequency: Max 1.5Ghz
CPU: High performance Dual core Cortex A9
RAM: 1GB DDRIII
Operation System: Android OS 4.1
Display: 7" TFT LCD, High resolution, 1024x600 pixels IPS Panel; capacitive touch screen, support multi-touch
Function Features
WiFi: 802.11b/g/n
Port: USB 2.0 high speed port, OTG
Storage: 8GB Nand Flash
Removable Storage: Can be used as portable hard disk
Storage Card Type: Micro SD card (Support external maximum 32GB Micro SD Card)
Audio Output: 3.5mm earphone, speaker
Input Method: Android soft-keyboard
Camera: 2.0 Mega pixel front
Audio Format: Supports MP3, WMA, EQ Sound Effect
Video Format: Supports RM, RMVB, AVI, MKV, WMV, MOV, MP4, DAT,VP8, H.264
Picture: Supports JPG, BMP, PNG etc, support rotate/slide show/zoom etc. play function
Other Applications: Supports video on-demand, web browsing, on-line chat, e-mail, e-book, sources management; Supports clock, alarm, calculator, recorder
Sound Effect Mode: Supports Normal, Popular, Rock, Classical, Woofer, Bass, User
Repeat Mode: Supports single play, single circle play, ordinary play, all player cycle, listening test
Record: Supports microphone; supports MP3, WMA, EQ Sound Effect
Technical Data
Battery Capacity: Rechargeable lithium battery 3500mAH : 4-5 hours while being used, stand-by 5-9 hours
Charger: Micro USB 5V 2A
RAM: 1GB DDRIII
Function Features
WiFi: 802.11b/g/n
Technical Data
