How to save PRO/RAW mode in Samsung S10e camera app?
peterh337
There is a lot of stuff on google about this but as usual none of it works.
It refers to an option like "save settings" in the camera app, but there is no such option.
Maybe Samsung removed it recently?
If it really has been removed, what is the least crippled 3rd party camera app for the S10e? I am not bothered about the wide angle lens; I know that the S10/S20 series cannot do RAW from anything other than the main camera.
Many thanks for any tips...
You could try "Open Camera" - I have that on my Pixel and can save RAW from that (while the Pixel Camera app does not have the option to save RAW).
Thank you. This is about the 5th camera app I have tried, and YES it works!
Filmic Pro and Camera FV5 are no good on the S10e.
Enabling RAW took a bit of time finding but with help from this
https://opencamera.sourceforge.io/help.html#raw
I did eventually work it out.
The focus also seems to work, which was always a problem with 3rd party camera apps on the S6 onwards, IME, due to the crippled Samsung public API.
I just need a basic RAW camera (with exposure control) because the rest is done in Lightroom. The 12MP sensor appears to be same as S7, S9, etc and the results from RAW are very good.
