kingmaster
Hi All,
Recently i used NFC tags,once i write the data and i can set to write protected so no one can able to rewrite the tag but one problem is anyone can read the tag data,i want to set the password on read protected.
if anyone read the tag its ask password,if the user input the correct password then only the data will visible otherwise its not visible the data,its possible ??? its possible means how to set this type of option?
