Abhishek Mittal
All the Android apps store their data in "/storage/sdcard0/Android/data" folder which is in internal memory. But there's a corresponding folder in MicroSD Card(external storage), "/storage/sdcard1/Android/data" where very few apps store data and that too in very little amount. I know it is due to limited permissions. So I have two questions :-
1. Is there any way/hack that if I shift this data of a particular app, manually from internal storage to external storage, I can make apps use it? (I'm getting low on internal storage. I tried shifting data of "Pocket" and "Cousera" apps but it didn't work.)
2. As Android Lollipop will again remove this restrictions on external storage handling from apps, will they all start saving/shifting data to external storage saving space on internal memory?
(I am using Moto E(XT-1022), Android version : Kitkat 4.4.2)
