How to Show Battery Percentage?
Staff
Android Expert
To show the battery percent indicator in the status bar of your Galaxy Z Flip at all times, you'll want to pull down the notification tray and then select the following:
You'll then see an option to:
"Show battery percentage"
Select that option and you're good to go!
